blowedupmotor87
Hey y'all, we're having a bit of a time of it fitting my doubler in (465/short adapter/203/2" upclocked 205/HAD driveline e-brake/triple sticks). Although I acknowledge a body lift would make this easier, I have no desire to run a body lift, just want to cut/weld to fit. I was wondering if anyone has a similar setup and has some pics of what mods they had to do to their floorboards and tunnel to fit 'em? Thus far we have: cut the tunnel where it dips down toward the back to clear the e-brake, and cut right up to the passenger seat mount to clear the 205. Anybody have a good shot of what needs be done to accomodate the shifters? Any tips/advice?
Also, if anybody has pics of custom crossmembers they made to fit their doubler, that'd be really helpful too! I'm thinking a good bit of tube bent up and mounted in such a way to allow the greatest clearance it can with a large belly pan that is bent up on the edges to facilitate sliding, suggestions, pics, ideas?
Thanks everybody!
Thanks everybody!
Overall length at rest is about 39" though, and the angle is quite good. I was really hoping for equal length driveshafts but that didn't quite work out. I was also hoping to run 1410/1410 shafts front and rear...which also didn't quite work out. The rear shaft is shorter than I'd hoped, and runs steeper than I'd hoped. It's currently 1410/1410, but the pinion has been rotated in preparation for adding a high angle CV head and companion flange. I have the parts, just need to take some measurements and send it in to be modified.
