Need Some help guys!!!
19Blaze82
Registered Member
Westminster
Hey Ive found a late 80s Chevy 3/4 ton with a 400 small block. I wanted to take the axles and engine out and put them in my truck (A 1982 K5 with 1/2 ton and a 305). I know the engine will bolt right up. How about the Axles. I made a post a few weeks ago. Ive been researcing and looking around and cant find anything. It all either for different axles or not what im looking to do. What i am wanting to know is will the axles bolt right up? Will i need longer/different brake hoses ubolts??? Thanks guys any help would be great.
It'd be easier to switch bodys wouldnt it:dunno:
NO
The rear axle will require different u bolts, get the top plates with the axle if you can. You can get top plates from DIY4x too.
Other than that the axles pretty much bolt in, front is a direct bolt in.
2 sets of ubolts and mabye brake lines and few odds n ends much faster than rusty nasty body bolts and body swap.
check your other post for more info.
