Need some help with the headlights
uglyangelracing
Rhode Island
Ok so everything worked fine before but the truck sat for a while because I lost interest. Then I got a new trans dropped it in. All excited to drive it to work today and headlights didnt work. Got home from work started testing. Turn headlights on and nothing for power at terminal. So running lights work decided to try directionals. Left blinker nothing. Right blinker turns on headlights. Im thinkin a ground or headlight switch. What do you guys think?
Headlight switches do wierd **** when they die. Get a new one, it will be $15 well spent. Even if it isn't the only problem.
Check the ground from the battery to core and harness behind the battery gets knocked off easily.
