[ QUOTE ]
You reconnected the power wire to the right terminal on the HEI right.Double check,maybe it connected to the Tach terminal.
[/ QUOTE ]
Yeah, the wires to the HEI were fine so I pretty much just left them alone.
[ QUOTE ]
Do you have spark at the plugs?
[/ QUOTE ]
Not sure, I'll check when I get home.
[ QUOTE ]
Is the replacement wireing harness a factory replacement?
[/ QUOTE ]
Yes it is
[ QUOTE ]
Is the wire supplying power to the HEI a orange/white wire covered with fabric insulation?
[/ QUOTE ]
No, it's a red one, I think like 10 guage but don't quote me on that.
[ QUOTE ]
When you say "it Cranks and cranks but won't turn over" that confuses me a little.
I've always called it cranking when it's actually turning over.
Is the starter actually turning the engine or not.
[/ QUOTE ]
Yeah, the starter is trying to turn the engine on but it just won't fire up.
[ QUOTE ]
The fire prob. took out the fusable link at the Battery.
The fusable link will burn up when there is a extended short in the system.Prob. saved your truck from being burnt to the ground.
If the fusable link is burnt up you won't have any juice available to get sent to the starter solenoid when you turn the key.
Do your interior lights work?If not there may not be any juice getting to the cab.Therefor nothing triggering the starter to turn over when the key is turned.
[/ QUOTE ]
Everything works, it's just not firing up. I'll check to see if the plugs are getting a spark when I get home in the morning.
