RubberFloorMat
I dont have any internet at home due to the company sucking ass. I could use some help with a couple things that are blazer specific.
Anyone using a manual rear window crank without a lock in place? what are you using to engage the clutch?
Im running a NP 205 and recently got the factory t-case mount to bolt to the frame. I want to replace my shitty exhaust but i want to run a factory type y pipe into a large single pipe on the drivers side, into a 2 into 1 muffler and then dual pipes out either side. What are you using? is there a 2.5" Y pipe on the market? is there a dual muffler back with tailpipes kit that im not seeing or is it all muffler shop built?
Where the hell does one find the proper rear seal for a long tail GM np205 case?
