need some parts
1967k10
Nebraska looking for D60's
Parts we need to finish up my brother's truck.
71'/72' Eaton hubs with the 9/16" studs
Van width Eaton axleshafts for spares.
14bolt disc brackets
67'/68' radiator support
205 pinion brake
ect
wont the hubs from a 14ff fit. i have heard lots of the 14ff stuff swaps over.
and i have a h.a.d pinion brake kit for 205 . pm me.
205 pinion brake
ect
Do you want a 67'/68' core support or a 71' would work?
I think they are the same up to 72' right?
I still haven't provided you with a pic of the column, are you still interested?
My friend has a bunch of eaton, I will see what he has.
67'/68' are different :( .
What collumn??
I'd appreciate it on the Eaton parts.
What collumn??
Oh well I thought all 67-72 were tha same with Chevy, i know the GMC is different with the dual headlight setup.
The steering column we had talked about, and you said you wanted a pic. Which i never sent.:o
Manual steering column for a 67-72
I might have a radiator support. Exactly which one are you looking for? Chevy or GMC?
Any chance you could send a pic so i can be sure it is correct. It isn't rusted.
Mike
I grabbed a pic from LMC. I believe it is the one I have. I will look sometime before the weekend.
No need, I won't tear it apart unitl you verify it. I will try to get some pics by the weekend. I believe the donor truck is a 68/69 C/K10. Providing that it is the same as the K20 and no-body every tinkered with it i...t should be what you are looking for. I had the hood open last weekend and didn't see much for rust. I will verify this as well.
