need some welders advice
wraenking
Toms River, NJ
well, my friend from work fixed my shock mounts for me. just want some opinions as to if they will be ok. i still have to re drill holes in them, but my other buddy says they are no good. i dont care either way, but i would like to get it fixed now before i attempt to put them under the blazer.
i don't knin that firt pic the steel looks thin, and i can't really see the welds to good. What kind of steel did he put on there? i would not put anything on that was smaller steel then stock, anysteel you get is mostlikely not as strong as stock (untempered) it might be ok around town, but /forums/images/graemlins/dunno.gif
dose your friend do welding alot or dose he just have a welder?
I'd have to cut that off and start over.
[ QUOTE ]
[/ QUOTE ]
/forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
Holy booger welds batman. Definatley need to start over on those.
I agree, those need a do-over by someone that cares about what they're doing and has the skills to do it.
Darkshadow, stock shock mounts and axle tubes are plain old mild steel...
Rene
Those welds look cold. Cut them off, turn up the heat and try again. Good way to learn welding. If you welds suck you'll find out real quick.
-Chris
[ QUOTE ]
Rene
[/ QUOTE ]
ok but i bet that it would be punched out of cold rolled steel.
I'd put money on plain old hot rolled. Nobody in their right mind would bother using cold rolled to make a stamped part...
It's just a complete waste of what cold rolled is good at, which is being flat, square and very accurate dimensionally.
Lastly, cold rolled is still mild steel, just with a helluve a lot more inherent stress and no mill scale.
Chevy frames...also plain old mild steel.
Rene
I'd say you need a new friend or at least give this one a good smackerin.... My guess is that first pothole and those mounts are gone anyways.
Cut em off /forums/images/graemlins/hack.gif, find someone that can weld and do it again. /forums/images/graemlins/weld.gif
