01maroonz71
well, it all started about 1-1.5months ago when i was driving down the road and shazam!!! the steering got a mind of it's own(so bad it was unsafe!!!!)....jerking left and right...so i figured my frame was cracked....a day or two later i pulled the steering box off the frame in my apt complex and cleaned it all up...i found what i think is a crack but i can't be sure...it doesnt come off of a bolt hole, but where the box would meet the frame, around the edge...it's shaped like a U and is only about half of an inch. i also found two broken grade 8bolts, which i figured is what caused my problems. so then i ordered the weld in brace. got that, and a new steering box while it was off.
so, i can't find a mobile welder around here, so yesterday i put the new box on, bolted it all up with new bolts, topped the fluid off and WOAH!!!! didn't steer worth a crap....popped the cap off the pump and lots and lots of bubbles and white isht was in there....so last night i searched and found the RIGHT WAY to bleed the system....just did that. unhooked the pitman arm and worked the steering wheel back and forth for about 20-25minutes until the fluid level was stable and the bubbles were gone...threw the cap on and drove it again......well, the truck tries REAL HARD to return it self to center and feels like i have no power steering(or very little if any)
any ideas what this could be??? im trying to get it to my welder about 2miles away to weld this brace in. is it possible that i need a new pump??? oh yeah, the high pressure line is brand new also.....
thanks, and sorry for the long azz post!!!!
