OkI don't know if it was conclusive that anybody ever got a large bore (truck) box with the lower ratio number, or if the only ones out there are small bore (car) boxes.
https://ck5.com/forums/threads/steering-box-recommendations-poll.344024/
Please elaborate on PSC, i dont know themOk check all the stuff you need, like the guys are saying. Also you can upgrade to a whole new system from PSC. If you are planning to do some upgrades. Then I would install the one you want later down the line!
Disregard. I found them. $2300 for a steering box system is a little steep for this ol Sunday driver. If i was racing or doing heavy duty off roading, perhaps.Please elaborate on PSC, i dont know them
Yep that hard part is to find the right setup.Alright I need to ask. Can a steering box K series ccw box be converted to a cw box by changing the worm gear ? I am guessing not, or this would be preferred over going to a whole 2w drive box.
When I did cross over on my sons 67 f250 I use a 78 bronco p/s box with a 2whl drive worm gear to change direction, worked well and was an easy conversion. Hardest part was sourcing a 78 Bronco box
