need time opinions and a NP241 question
surpip
1 ton status
sacramento ca
i have to replace the input seal on my t-case, the o-ring beteweent the adatpor and the tranny, and drain and fill both axels and replace the pinion seal on the 14ff, think i can do all this in 4 hours? Ill be on base so i will have tranny jack and a lift and everything i need
What do you think /forums/images/graemlins/dunno.gif
Re: need time opinions
not unreasonable. Diff fluid is easy, not sure about the pinion seal. T-case isnt hard, just kind of a pain getting the bolts
cool the place opens at 1200 and i have to be to work by 4:00 so im hoping i can get it all done so i can go up to the mountians this weekend
oh and how do you replace the brass bushing in the tailshaft of the 241????
you need to remove the tailshaft housing and press the bushing out the back. ive heard someone use a punch, but a press is better. /forums/images/graemlins/waytogo.gif
alrigh i was told its not worht it to just replase the output seal but you have to do the bushing to? sound about right? i bought it just in case, only like 3 bucks
