ciffer
In my backyard I have a steel post cemented into the ground. The post and cement are in the way and need to be removed. The post is put off about 10 inches above the cement; the top of the post is just slightly below the surrounding ground (the cement and post have a hold dug around them at the moment).
The cement piece is about 18 inches across, and pretty deep, not sure how deep because I haven't found the bottom yet. It is too heavy for me to lift, too awkward and too low to lift with two people, and I really don't want to break it up with a sledge hammer if it can be avoided. I can probably roll it myself once it is out of the ground.
I have access to heavy chains, one suburban has tow hooks in the front and the adjacent property has a parking lot that I can easily put the suburban on and pull, and enough room that can chain two truck together if needed. The adjacent property also has a convenient rubble pile where my cement/post would not be noticed.
I need tips on how to rig the chains, how I need to dig to prep the post to be pulled out and any general tips. I'll get a picture in the morning.
