Need to borrow a tool - Blind Rivet Nut tool
badmix
West Virginia
Im putting a latch on my bumper to keep my tire carrier from rattling. I was thinking of using rivet nuts in my bumper. I dont want to use 4" long nut and bolts and I dont think any screws would work.
I know those tools are expensive, Im going to check a body shop I deal with but otherwise not sure. I checked Carquest, they are 70bux for the tool. I only need it one time.
So, does anyone have the tool to share? I can pay shipping both ways.
Or does anyone have any better ideas? Thanks
For those that dont know what im talking about
I have used these inexpensive tools for both 5-16X18 and 3-8X16 rivnuts.
catalog page 3271
http://www.mcmaster.com/#additional-tools/=8fnnkf
Wrench-Drive Rivet Nut Installation Tools Easily install knurled and standard rivet nuts as well as rivet nut inserts with these manual installation tools. Each includes two mandrels per thread size. Use with steel, aluminum, and stainless steel rivet nuts and nut inserts. Use a 7/8" wrench (not included) to hold the tool and a 11/16" ratchet (not included) to tighten the nut.
Being that I deal with these daily (military loves em).... I have a work around to offer.
You need an impact (preferably 3/8, dont want to much torque).
Grab a long bolt which is the same thread size and pitch of the insert, a non locking nut, and a washer or two for the bolt. In this order, assemble the hardware.
bolt - nut - washer - insert
Install the assembled insert to the hole with the bolt thread flush with the bottom of the insert. Hand snug the nut to the insert, meshing the washer in between the insert and nut.
Hold the nut with an open wrench - You do not want the nut to move when you start to set the insert. "Tighten" the bolt with the impact - The faster the better.
The nut acts as an anchor for the bolt to pull the insert to a seated position. The flat washer prevents the nut from digging into the surface of the insert.
If you need clarification, just ask - I can throw a set of hardware together and snap a pic pretty quick.
Troy B
Ft Hood, TX
