I need to weld a water manifold that is cast iron. Should I use the TIG or ARC welder? What type of rod should I use?
Also, it's small enough where I could fire up the grill and warm it up so it could be welded warm and cooled down slowly, but it's not a structural part and it won't see very high temps (I'm thinking 200-300 degrees F). Do I need to do that or could I just weld it out in the open in the garage?
