Need torque specs quick
4X4HIGH
1 ton status
Fremont, CA.
I am assembling my D60 front and need torque specs for lower knuckle bearing cap bolts and upper king pin cap bolts as well as spindle to knuckle nuts, (the 6 nuts that hold the spindle and knuckle together.) Also just to refresh my memory how to do wheel bearing adjustment properly. IIRC torque inner nut to 50 lbs., back off and then retorque to 35 lbs., add washer and then torque outer nut to 50 lbs. Is that correct?
