needed 2wd leafspring hangers 1ton frame style
sweetk30
Back to play nice .
in the back of your brain
i need a set of hangers for a 1ton 2wd frame for the front end of the rear springs.
thay will fit in a usps flat rate box and ship cheep and fast. :D
need 2wd and 1ton frame. then it dont matter if srw or drw.
true 2wd = 3" shorter hanger
1 ton for 1" less stick off the frame for narrower spacing.
ok.. yes ... thats where i was wrong.. i was thinkin dually were the shorts and single was long but its 2wd short and 4wd long... let me look i had a few 2wd dually 1 tons.... would you have a nice set for a 1 ton 4x4 you would want to trade ??
will have a set when i perform frame swap/truck rebuild next month or so coming off old frame. not sure how solid the old frame stuff will be . but if i got and good you are more than welcom .
how soon do you need these ?? i have them.. they are off a 86 k30 dump and look nice and solid.. they are still on the leaf packs up on a racking unit ... problem is getting to them with all the snow we have..
c-30 = 2wd
k-30 = 4wd
what do you have ?
i need 2wd prefered.
and no fast time needed. wait till snow melts is fine for me. as my project is covered in snow also.
