needing spring help
JLBk5blaze
Registered Member
defuniak springs FL.
im currently running 6in rough country front springs they ride like a brick and flex descent. im looking for another set of springs that flexs better and doesn't ride so rough.. Im not doing 52 or 56in swap!! Should I look into custom springs or is there something out there that is production that is good? thanks for any info...
Rough Country is known to be one of the stiffest brands out there. Tuff Country brand springs are supposed to be a good quality product with fairly soft spring rates, Off Road Design carries these as well as custom built stuff.
I guess they call them rough country for a reason!! I know tuff country has the soft ride or ex ride which ever they call it just like to get some input from someone running them. Maybe someone will chime in.. But thanks I'll look more into it
My K5 has some awful front springs on a 4" lift, on the K30 I had ORD build me springs, couldn't be happier. They flex well, can't compare em to tuff country springs as I've never ran them. I'm slowly rebuilding the blazer and when it comes time for suspension I'll do the ord's again.
