Anyone have one? I'm thinking about buying the hf unit, but it is 60 bucks. Not sure I'll ever use it again. Just need to clean up some flake on my frame. If anyone has one Id be willing to rent it from you.
I am not impressed. It probably works ok for some specific applications, but with hand held wire and grinding wheels and flap disks, I felt it was slow, and just didn't do a very good job getting through stuff.
I'm sure it would blast through heavy scale, but so will my stout wire wheel, and it or the flap disks will take it down to bare metal, the scaler will not. At least nowhere near as fast.
Sounds like a knotted wire wheel is in my future.
One thing I had bought it for was getting into those areas where brackets were riveted to the frame so I could paint. Did not work good enough to paint. To the scalers credit, a wheel won't work there either, I would assume blasting would be the choice.
If you don't take it down as far as i did mine, a wire wheel would probably be faster than a scaller. Blasting would get everything though.
A good powerwashing before hand can knock off some of the big stuff too if it's flaky undercoating.
