Neutral Safety Switch
Adventurous 4x4
Carlisle, Pa
On a 90 K5. I am building it into a truggy and it will have a aftermarket steering set up so the stock column will be tossed. I need to know if I have to bypass the neutral switch so it will start? If so can I just tie the wires together? I will be using a ign switch with button starter. Anybody have good wiring diagrams on what wires I need to use off the column for the start switch? Yeah, I hate wiring!!!:crazy:
on my 75 its just connecting the two purple together take the plug that plugs into the Neutral Safety Switch take a short section of same gauge wire add spade connections to both ends and put the end in the plug works for me as for wiring diagrams http://brochures.slosh.com/ under wiring has some.
