So you went the distance and put the Greasable bolts in your leaf spring suspension. Ya go wheeling and knock all the grease zerks off, well not anymore.
Pictured is a full front end set for $55.00. The smaller cup washers are for the very front end of the front spring. Basically a 1/4" thick washer with the "Z"erk "A"rmor on it.
This would also be the same set up you need for your rear springs if your using our Shackle flip-n-switch.
These will also be available in different lengths, cross tied and different diameter holes. The UDSR shackle will also be made available with the ZA upgrade as well.
I will get all these put on the Website ASAP.
Here's a picture of the Shackle side with a Greasable bolt head for reference.
