New 409 bbc...
76zimmer
Flyin Rat
Staff member
Moderator
Kzoo, Mi
If I knew this was coming, I wouldnt have bought a 454....
based off a BBC Merlin block, but decks angle milled for the 409 heads, and water pump jackets added for the 409 pump. Everything else in the block is BBC
How is this better then a 454? Less cubes = less torque/HP generally.
I think the 409 put out gobs of power (close to 400 hp) and/or 409 lb./ft. torque when it debuted in the 60's. Not sure though. Must do research later.
Im really suprised it hasnt been done sooner actually, ever look at 348/409 stuff on ebay? That ****s crazy expensive, even in core condition.
You just go and get the W engine... then send me the 454:D
I would think that block would have to have a very tall deck to remove that much and still have any real stroke to speak of. talk about an over square bore/stroke. And doesan off the shelf intake for the W engine work on these or is that a special thing for this engine?
dad knew of 2 427 mystery motors, one was a complete car, but who cared back then?
Kinda neat for them to redo the old 348/409 motors.
Imagine... trolling for ricers with that under the hood of a red on red 63 Impala. Do it all up to look stockish... the ricer punks wouldnt know what hit em.
does losing hurt all that much more when the car that beat you, weighs twice as much as yours does?
I'm gonna run Rallyes on it . Funny those hubcaps came off a 71 C10 and they fit the stock steelies perfect .
You better start a build thread for that thing.
Well its In Two Harbors MN In my Dads shop . Its kind on back burner until I save up for floor pans,front fenders and a door skin. its All original except for the tires 6-Cyl 3-speed. over 300,000 miles my Great Grandfather Bought it new in the Fall of 1960
Plans are : full restoration .
Then Add 4-wheel Disc,T-10 4-speed,and a V8 of unknown size as of yet
going for a Sleeper look , and if you wanna see under the hood it will cost you!
I want to build a angry small block, but have some top of the line aluminum heads cnc machined to look like camelbacks, I love the whole sleeper idea...
Good thing that car is so complete, 61 is an odd year. dont see many of those around. And black with the red interior is epic awesome.
My grandpa had a 63 Impala, red on red. My grandma said it had abot 250K when they took it to the junkyard.
I have a friend i duluth who has a few Old cars too, has a 64K mile survivor 63 SS Impala. I enjoy seeing them how they were back then, not how much nicer a restoration shop can make them. And yes, Ill have to come up an take a peek under the hood sometime when your back in Mn.
Yeah the Interior is in Perfect shape. the car is actually very solid it only really NEEDs a drivers floor pan but since I'm gonna do a Rotissere resto I figure I might as well just do the whole floor .
I plan on mini-tubbing it as well and then have a custom set of wheels made that appear stock but will let me run a Big Ass rear tire.
in this case 409 is just the engine type, not c.i.
Merlin-X 409 Engine Prototype - Legend In Aluminum
While we were at Walden's...​
read full caption​
http://www.superchevy.com/technical...12_merlinx_409_engine_prototype/photo_10.html
While we were at Walden's shop, he was doing the final test fit for a March serpentine belt drive system he's prototyping for them. This should be available by the time you read this.​
World Products has teamed up with Lamar Walden to develop a brand new aluminum 409 block-big news for anyone wanting to put one of these legendary engines on the street or race track, and great news for the restorers, as they won't have to compete with racers and rodders for blocks.
Lamar started with a new World BBC aluminum engine block, and began converting it over to 409 specifications, beginning with milling the 90-degree deck and fabricating a wedge to correct the deck angle so the heads would bolt up. At the front of the engine, Lamar closed off the standard BBC water pump ports and located a set of mounting bosses for the 409 water pump. Rather than reinvent the wheel, the standard BBC timing chain cover and oil pan rail were retained, which is a nice bonus for customers.
With the deck angle, combustion chamber and water pump bosses adapted to the block, Lamar sent it back to World, where patterns and molds will be pulled off of it to start casting with brand new aluminum 409 blocks.
http://www.superchevy.com/technical...12_merlinx_409_engine_prototype/photo_11.html
Walden has developed his own...​
read full caption​
Walden has developed his own line of aluminum 409 heads, based off the -690 high-horse factory castings, and the Z11 race pieces, depending on your needs. He also has intakes, including this EFI unit. As delivered, the Merlin block will displace 509 ci, with a 4.500-inch bore and 4-inch stroke crank, the crank of choice when building a 482-inch iron block stroker. With a big 43/4-inch arm, and the bore maxed out to 4.600, displacement is bumped past 609 ci. The -690 heads will work very well with the "small" Merlin block, while the big one will require Z11 heads.​
Enhanced blocks are one of the benefits found on World's BBC aluminum castings. Lamar once built a twin-turbo 409, and found that with enough boost, the block will split through the lifter valley like a piece of firewood, only holding together with the bellhousing and timing cover. World blocks feature thick reinforcements between both banks through the lifter valley, not only keeping the block together, but limiting bore deflection under load as well. The World BBCs also benefit from a relocated, raised main oil galley, allowing billet four-bolt splayed bolt main caps, which ship with the blocks, along with premium fasteners-the mains will be the larger BBC diameter, so material doesn't have to be removed from the webbing as when a factory 409 block is align bored to BBC crank specs.
The cam journals are also the standard BBC specs, while stock 409s share cam journal diameter with the small block Chevy, and the journals are raised to in the block to clear big stroke cranks. The World 409 blocks will also have a thicker deck, eliminating the tendency for the block to crack there. Walden tells us the blocks will come standard with a 4.500-inch bore, and can be take out to 4.600-inch. "With a 4-inch stroke crank, and long 6.135-inch rods, it'll be 509 ci," Lamar told us.
His LWA aluminum -690 heads flow enough to support over 500 cubic inches, so running one on the street isn't a problem. Max out the bore and adding a long stroke 4.75-inch crank pushes the displacement to a tick over 630 cubic inches, and you will need a set of Walden's Z11 aluminum race heads. Is there a Nostalgia Outlaw class?
Final pricing won't be determined until the first run of blocks come back from World's foundry, but they should be in the same neighborhood as World's Merlin big-block Chevy castings, and not much more than you'd pay for a good passenger car block fully prepped and ready for a 4-inch crank. That's a pretty good neighborhood, and one we can't wait to buy into.
Just sad the 409's don't have bosses in the heads. A good place to find rare pieces if you wanted to build one. www.348-409.com , or, www.show-cars.com . also known as dr409 on ebay. I have bought many a parts from dr409. Great company. Just check out the prices just for a clean block. Insane prices
Thanks Zimmer!!! I have to to get one !!!!! anybody no aplace I can sell a Kidney??
:bow::bow:
Wow a 630cid 409 holy crap, I need to sell a kidney too!
What a perfect motor for a 1700lb t bucket :D
