Thanks for the links guys!
I decoded it all, most is pretty bland as you probably know. This is a good one too:
http://www.gm-trucks.com/rpo-code-lookup
What 62 already said:
GU6 -3:42 gears
G80 -Limited slip (Gov-bomb?)
JD7 -Brake, hyd power, disc/drum 8400lbs
Other highlights:
MT1 - 4L80E
C36 - HEATER AUX
KNP - COOLING STSTEM, TRANS, H.D.
NP1 - T-CASE, ELECTRIC, FULL RANGE
NZZ - SKID PLATE, OFF ROAD
NY1 - SHIELD, FUEL TANK
YD3 - FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING GVW PLATE (does base mean 1/2 ton?)
YD6 - REAR SPRING, BASE EQUIPMENT
ZW9 - BASE BODY AND CHASSIS
Z82 - TRAILER PROVISIONS, SPECIAL EQUIP, HO
JAN - JANESVILLE, WI
Why do you call it a gov-bomb? Some good grenade stories? My '93 3500 has one. I was trying to figger out if the 4x4 was working after I got it. I got the LR wheel in the air, spinning away. I romped on the throttle for the hell of it and the truck jumped forward and climed the little bank I was on. This would be crap for wheeling but I think it's pretty damn handy on a DD.
Here's some interior pics. Not in bad shape, this is after I cleaned it and armor-alled it.
