New 80 3/4 ton 8 lug brake rotors
crazy427
Edison , NJ
Have a Brand New set of Raybestos 3/4 ton front brake rotors. They are 8 lug. these are the ones you would use doin a disc brake swap on a 14bff or if you are converting your front 6 lug 10 bolt to a 8 lug.
50 for the pair
ill think ill take them, give me until the weekend, but if someone else needs them let them go first
not, 100 % sure if you call the local parts store you should be able to see if the rotors from a 75 3/4 ton interchange with a 80 3/4 ton. If they do then yes they will fit.
Joe
