New addition to the tool arsenal.
Baddog on the topic of the Norton 38A wheels. I want to use my old 6in bench grinder for a sharpener as its a little under powered for the typical wheel and wire wheel on it now. Would the 42A be a good choice for one side and a china diamond wheel for the other side in terms of doing HSS and carbide? Or should I go for a green wheel on one side and diamond on the other?
Forget about the green completely. A good HSS grinding wheel on one side, and the diamond on the other would be good. But be aware that most brazed carbide grinding is done on a flat side wheel such as the 6A (IIRC). The hollow grind of a peripheral wheel is not desirable on carbide, though it is on HSS. Also note that you'll need to keep grinding of steel on the diamond to an absolute minimum or it will ruin the wheel. So if you start getting close to the steel on a brazed bit, you'll need to clearance just enough so that it doesn't eat (literally) your diamond.
And 6" is tough to get good wheels for, though with searching it's possible, but they tend to cost more. The most common size (by far) for good wheels is 7", because that's the size used by the vast majority of smaller surface grinders and tool grinders. But, those grinders use hubs, so the wheels have 1.25" holes, and making an adapter hub is an excellent early lathe task. But that doesn't help you on the 6" grinder. I use a 7" grinder, so I can't help you much there, though I know it's been done (or rather I've seen posts). As to the 42A, you'll have to look that up, I'm not familiar with that designation's application. Harold and others on Chaski are a HUGE wealth of information regarding grinding, and you may find the answer to most of your questions in the threads I mentioned. If not, I'm sure they will be able to provide better input that I can. I basically learned what I needed to make mine work for me, but I don't have the broad general (real world on the job) knowledge they have.
Here is some of the smaller tooling I have. Everything else is way to big for that machine.
10 + years of machining experience here, and just want to pass along a few things for a self described "noob":
1. Wear tight fiting clothing, NO LONG SLEEVES, NO LONG HAIR, NO RAGS IN YOUR FRONT POCKET, or anything else that can get caught in the chuck. That lathe will wrap you around it in a heartbeat!
2. Don't use a rat tail file without a handle! If the file catches the material, that rat tail will go through your hand or wrist.
3. If polishing the material with sandpaper, emory cloth, etc... watch your fingers! Again, that lathe will wrap you around it in a heartbeat!
4. Keep an eye on the lathe. Jealous forum members or neighbors may attempt to "borrow" it. :thumb:
P.S. I've done all three of the "do-not-do's" that I mentioned. Just be careful!
