jeremywrags
Hi all,
I am finally putting my 72 jimmy back together, new body mounts, some new metal carpet, gaskets...
I put the passenger door on yesterday and the gaps are off. It seems like the window frame is leaning back by about 1/4 inch. The area near the wing window at the top of the door hits the window frame whilst the back of the door is ok but even a little tight.
I have the hard top on and from the looks of it, it is sitting about an inch to far back. We tried pushing it forward but no luck.
It seems like if the top could be in the right spot then the other issues would go away as well.
I Heard the the angle of the window frame has a lot to do with the body mounts, can anyone please give me some info on how I might go about adjusting this?
Also a friend suggested making a "relief" cut in the window frame just above the dash, pushing it where I want it and then welding it place. I am not totally against that but it seems like a lot more work and has potential to really screw up?
Please give me some advice, all opinions are appreciated...
