az-k5
Haven't been on here in a while and now I am having a melt down. Just put a new cam in the truck. Got everything buttoned up and went to crank it over, heard a ticking. Stopped, tried to turn it over by hand. It stops at one point, not each valve. It will go revers a complete revolution and forward but stops. I pulled all of the rockers off and tried to rotate it, still stops. I pulled the fuel pump, still stops. I pulled the plugs and it still stops. Where do I start to look?
Matt
Specks on cam
Chevy 350
Operating Range: 1200-5500 RPM
Duration Advertised: 262° Intake / 272° Exhaust
Duration @ .050'' Lift: 204° Intake / 214° Exhaust
Valve Lift w/1.5 Rockers: .420'' Intake / .442'' Exhaust
Lobe Separation Angle: 112°
I have it 4° advance on stock 882 heads with 1.6 rockers.
Matt
Specks on cam
Chevy 350
