Re: Clutch
A rig that size might have a 13 inch clutch,or possibly a dual disc setup.I love the style of the 60-66 trucks.A guy I used to set up next to at a swap meet had a factory camper C-60 truck very similar to yours,his had a 427 tall deck factory in it(wouldnt run when he bought it,thought it needed a timing chain,but it had a factory gear drive cam in it!-turned out to be the drive gear on the distributor had sheared the roll pin,throwing it out of time).It could be the original rear end went out in yours and someone put in a 2 speed,and left it disconnected,if there is no means of shifting it in the cab.Our local dpw still has a few golden oldies like yours in the fleet of dump trucks they plow and sand with,I used to sell them those clutch discs that look like a fan blade with disc brake pads on them--you cant "ride" those type of clucthes much,they engage rather abrubtly,but they outlast all the other types under heavy loads,something you may want to consider,since you will be loading the truck to capacity. I wish you luck on your move--did you say your moving to NH?--if so welcome to New England,the most expensive place to live in the US,hope you brought your wallet!. /forums/images/graemlins/ignore.gif
