New complete frame
Nope. Find a clean doner with a straight clean frame. Run it.
You could ask Kert @ DIY4X (@cybrfire) if he plans to offer the replacement tube frame that they built last year. That was a bolt-in affair once he finished a whole pile of measuring and fabrication.
That was a fantastic bit of work right there.
Have those, not what I want.
Or bust out the welder. 2x4 and 2x6 tube
Yes I could but would like to buy this done by someone else, with stock positioned body mounts and other mods applied so I know that I can trust the welding.
This is exactly the information I was looking for if he will do it. Anymore out there?
As someones whos done this its the little stuff that gets you, especially if you want all your factory components to work/function properly and not re-engineer and reposition everything.
Stormis what type construction did you go with on your frame you built?
