Desert Rat
Fetch the comfy chair
Ok, got a new rear driveline made by High Angle Driveline. I opted to swap out the stock strap style 1350 rear Corp14ff pinion yoke for one of HAD's 1410 u-bolt style yokes. Here is my question, in an article on Pirate detailing the swap, the guy who does his says that his is a trail rig. As a result, he doesn't worry about the pinion pre-load. However, he qualifies that statement by saying that if you run the street, he recommends doing what the manual suggests. So, I print out the section of the manual on setting the pre-load. My queston is, will simply measuring the amount of ft. lbs. it takes to back off the pinion nut, then add 1-5 lbs. of additional torque when I swap out the yoke, be good enough to take the pre-load back to the original spec? And, if I just had the diff rebuilt with all new stuff, will I need to swap anything new in or can I just leave it as is?
I also see in the manual that they use a special tool that bolts to the yoke. What the heck is that thing? Is that simply a bar that keeps the yoke from moving while you back off the nut? And, why would you need it if the pinion won't turn anyway?
and drove it for probably 6months before selling it with out a problem.
