hickmanfab
Registered Member
So I installed my detroit yesterday and finally got around to drive it today. Well it seems to always be "locked" When I go around corners i will not release (without throttle of course). Basically it seems like the locker is grabbing and releasing as I turn. While some nasty grinding and pinging going on.
I know this sounds like a noob question, but work with me here. I never installed a locker before and I did it w/o help, so I more then likely screwed it up.
The only two things that I can think of is:
1) I left the shim in that is for the spider/side gears
2) My backlash is off on the ring gear. I just counted the number of rotations on the adjuster nuts, because I don't have the gauge to do measure my backlash.
If there is any one in NOR Cal. (Modesto area) that is free Wednesday or Friday and want to help me. It would be appreciated. Unless it's a simple fix.
). Thanks for you help.
. I guess my $25 membership just saved me 300+.
Guess i'll cross that bridge when it gets here.
