new diff cover installed
BIGRED74K20
Northwest
i just installed this new diff cover last week, and finally got some pics......
the cover's not my cup o' tea, but to each his own - i can see how some would enjoy it. however, i'm curious about the shock angles and mounts. can you tell me more?
My thoughts exactly
Dumb Question-Where's the drain plug??? I don't know much about that model rearend, but I assume it would have a drain plug in the cover.
than why are their two NPT plugs on the top of the cover? i would have put on in the center on the bottom,
but thats just me
oh and im also intereted in those shock angles.
LUKE
LUKE
i did not even notice that, i didn't really look closely either. good Q, why two on top of cover? makes no sence.
and it lets more air escape when filling, most likely you could use one as a vent to if you wanted.
i bought the 14 bolt which came out of a guys ramcharger so it already had the mounts welded to the axle(now there in more and higher) so i got rid of the staggered setup and went down to the junk yard and found a 80's dodge truck with no bed on it and took out the shock crossmember out of the back. then i had to shorten it by 3.5" to fit in my frame. i went to this is because it articulates better.
on the upper left side thats the fill plug which is a dipstick for easy reading. on the upper right side is another fitting for a breather or a diff temp sensor. and on the very bottom of the diff, to the left of the very bottom bolt is the drain plug
Looks very stout! I like that shock mount in the back and have been considering something similar for my rig.
that's pretty cool engineering - covers all the bases for sure.
