New fab bench
ktmoutfront
We live in the stupidest times.
In my shop. Doing stuff.
Was tired of not having a flat surface to clamp too and not having tools close
IMG%5D
Im jealous, I wish I had a wood burner in the garage.:D J/K
That one sweet bench. What did you use for a top? Looks like 1/4",are you worried it warping?
Looks like your gearing up for a project.:weld:
It is only 1/8". i spent a bunch of time making sure the frame under the top was flat. If you look at the bottom rails you will see where I welded them in the middle after I made sure the top was flat.
The wood burner was free from a neighbor. Takes the shop from 30 to 68 degrees in an hour.
I have a truggy I bought and plan to do a rebuild with a 38 Chevy truck body.
When do you have time to work? Looks like you spend more time cleaning the shop than using it! Nice table though!
I do not work at this time. It got in the way of my playing so I gave it up.
I just got the shop done. Now I need to work on the other 1600 square feet so I can work on the Jimmy and the truggy.
what's in the square tubing on the ends?? At first glance i thought they were welding rods but it looks like too long of an area...
Thats TIG rod. Steel, stainless and aluminum. I TIG almost everything now. It is so much cleaner and stronger.
Looks like a really nice bench. Don't do too much heating with a torch on the table top and it'll last a good long time!
