new GM crate motor and a 1st gen.....some questions
jakeslim
Napa, CA
I will be looking to drop a GM crate into my 69 k5. What should i be aware of related to mounts, oilpan etc. Is it a direct drop in? Also, I have a 4 speed manual..anything needed to put in a new crate?
lots of question in the next few weeks!
thanks,
Paul
make sure you put in the pilot bearing, also make sure the crate enigne is compatible with your flywheel. the engine crankshaft changed in 86 from a two piece rear seal to a one piece.
everything else should bolt right in, unless you are getting a vortec engine. then you would need a new intake manifold.
ARQ.
thanks. Won't be getting a vortec. Just a base crate with no frills. I wonder if I can get something with no intake, no carb, no starter, no distributor, etc. That way I can modify just a bit.
/forums/images/graemlins/waytogo.gif
most of the gm crate motors come minus dist carb etc. so you can buy the parts you want instead fo buying them twice! /forums/images/graemlins/yikes.gif
