cybrfire said:What are the main frame rails made out of on you guys' trailers? Thinking about building one much like what you have pictured here. Maybe a tad shorter though. 18' probably.
lar300mag said:Not sure, but its strong, I think it has 2 6" or 8" beams, one thing for sure gooseneck is the only way to go
my fenders are made from 6 channel, they will never bend
cybrfire said:I was thinking of using 2x6x.188" wl. rect. tubing for the main frame rails and then step it up a bit heavier in the neck. 2x6 is probably heavy enough for the whole thing. Most of these trailers that I have seeh are made of channel iron. Heavier ones from I beam.
lar300mag said:If I was at home I would send ya some pics, still got 2 1/2 weeks to go before I get off the boat...
lar300mag said:You'll never have a problem with the trailer swaying on you, its a lot more stable, not to mention safer...and then the cool factor-its a gooseneck--Just noticed your from Lufkin, Man the sh*t I used to do there when I was in school in Nacodgoches. Lucky I'm still alive
cybrfire said:I bet your countin' 'em down huh?! Been 13 years since I was on a boat!
lar300mag said:There Hiring, want to come back on![]()
