New guages?
filmsomething
cincinnati, ohio
Ok so my guage cluster is cluster ****ed(pun intended) It's broken to hell so I ripped it out and put in a stainless steel sheet, I need to pick up a tach, oil pressure, coolent temp, tranny temp, and volts. I want decent quality but I dont want to have to pay hundreds of dollars ether. anyone have any sugestions?
If you don't want to spend the $$$, then stock gauges from a junkyard is the way to go. If you don't mind spending a bit, find some autometers on e-bay and do this...
I second the e-bay suggestion. Look for autometer or autogauge. They're both great quality.
the old oil pressure sensor can be kinda hard to remove, just giving you a heads up.. :rolleyes:
