New Guy
stunter2boy79
Registered Member
Cleveland
Hello everyone. just signed up lil while ago. i purchase a 1980 k5 for 200 bucks. body is pretty much shot but no biggie on that tho easy fix. has a 350 in it. the clutch and maybe brakes are shot also. i been reading alot of old post and have been learning alot. plans are for a 4 in lift w 33s or 35s. have a ? tho if i do a 4 in lift are the brake lines need 2 be extended? want to kno before i start em
thanks
ps why cant i post in the 73-... thread?
Adam
You can't post in that other forum because it is for paying members. If you have the 80 already, the best investment you can make is the $25 for a year membership to this site. The search feature, as well as the other forums are well worth the money.
If you do a 4 in lift, you will most likely need to do some brake line work, since at full droop it could turn the brake lines into limiting straps.
