SO I ended up with a somewhat rusty 1991 crew cab and decided it was more than I want to deal with as far as fixing the rust, the cab is not too bad but the bed is scrap material and the frame has lost a good 10% of the thickness in the section of the rear axle.
So looking at things the wheels started turning, and I though if I would shorten the bed, but the frame is bad from the front hanger of the rear spring and back.
SO if I cut the frame at that point, and move my axle 56" forward using the front hanger as the rear shckle hanger and put another one in the front.
That would give me a wheelbase of 109" or 113" based on how I flip the 56" spring.
At first I was thinking I use it for my wagoneer which has a 110" wheelbase and I already checked most of the body mounts will lign up and it would be fairly easy, and I would have a real stout frame from a crew cab but stronger because it's shorter.
Then I remembered I already have another frame sitting so another thought came today while looking at the ext cab pickup in a CL ad.
Why not build that same truck with a shortened cab.
Taking some measurements I need to take half the door off and I will be able to fit a 39-40" tire in the back.
All that would be very easy because the frame will not be patched up, just bobbed and the bodywork can make the effort to remove the rust worth it.
What say yee?
What say yee?
. I say build an extended cab
