mill5471
My 85' 6.2 sat in a barn for a good 10 years or so before i got it. I got it all running and driving, but it has a "miss" at idle. I'm not sure its an actual miss, but that is the best i can describe it. It only is at an idle though. I put new injectors in thinking this was the problem but it did not fix it. Another thing is i have noticed quite a bit more white smoke with my new injectors at start up. Anybody? Thanks
...Mine was doing the same thing...I put in new injectors, bumped timing to every possible position...and mine ended up being 2 cracked heads
...i'm sure yours is simple...my "BUDDY-(F*cker)" put the heads on there cracked when he owned it
Its the orginal timing chain and has 116,000 miles on it.
