dfl701
ok i purchased a 21" led light bar from blitzpro. i got it all wired up kst night and tried it out and everything was great.
i followed this schematic to give you an idea of how everything is wired up.
so this morning i go outside to leave and smoke comes from the hood. my power cable from the battery and my ground are melting the sheathing off. i quickly disconnect everything and turn truck off. so heres my scenarios
1) i ran a main ground cable to the negative on the battery and then connected the ground from the switch, the light and the relay to my main ground cable by soldering them together. could this be an issue?
2) i have power to the light, but possibly connected something wrong?
3) my ign power from the switch is temporarily wired to my high beam fuse in my fuse box. this way the light comes on with my high beams.
what did i do wrong? i hate wiring and now i have to redo everything and i hope i didnt blow my light.
