Hey everyone, I've been lurking, reading posts but of course my issue is just a touch different. Anyways
1982 chev suburban 4x4 6.2 v8 diesel.
Whenever I tinker with it, I get into a world of pain.
So I, like an idiot, tried to do something about my valve covers leaking. But, on passenger side I couldn't break loose the aft most injector nuts (one closest to firewall and the one next to it) and driver side when I tried to break loose the one closest to firewall, injector started turning with it. So I stopped that nonsense right there and then.
I'm in canada, cold, snow, salted roads. I wasn't about to get into that.
I have an electric lift pump with spin on round style filter (water seperator) on my firewall. I bled that. It geysered out of there.
Continued bleeding. I cracked 5 injectors total. 2 on passenger and the 3 on driver side. Yesterday, it smoked and fired up (with the help of a battery charger with normal charge, boost charge and engine start feature).
It burbbled n smoked until i got a smooth idle. Everything sounded OK, looked ok. It was getting dark out, I considered it a victory and shut it down after 8ish mins running. (Block heater plugged in overnight)
This morning, nothing not even the rump rump of it trying to start. Even with a block heater I swear to God it hates starting.
But it gave me no pedal, like I had to bleed fuel all over again. So I tried cracking 5 injectors again and crank, my batteries didn't charge enough I guess, so it's hooked up now, gonna go try again.
But now, ultimate question, do I have a leak? Why must I go through this again?
While it was getting dark last night when I got it to go, I didn't see any leaks.
No spot on the ground this morning. No general wetness around the injectorsnthat might suggest a bad seal.
I'm suspecting that injector that turned with the nut when I tried to loosen. But still no wetness anywhere.
I'm hoping I jist didn't let it run long enough yesterday to clear out all the bubbles. I don't want tongo somewhere and have to bring an extension cord and wrenches and my battery charger to bleed the truck everytime...
And if it is the injector, I'll need to replace the fuel lines.
Can those be bought pre bent for an '82? I bent brake lines and honestly I might just switch to electric if I have to bend fuel lines. (Kidding), bit seriously I'd love to avoid that...
I'm just wonderingwhat it could be if I can't see the culprit of wetness or dripping or leaking. I'll fire it up when my batteries are close tonfull today and use the daylight to really peep around.
Anyways, thank you for the welcome to the forum cheers to all to who read n comment or have tips
