baker440ex
Registered Member
hey everyone, i have a few questions about the driveline in my 89 blazer, hopefully someone can help. here's the info: i just got it on the road after it sitting for a long time, and i've been picking away at it for the last 6 months or so. one of the things i did was throw on some 33's and 3" lift blocks in the rear, to compensate for the sagging rear leafs. when i took it out and got it up past 35 or so there was a real bad vibration coming through the dash on acceleration. (this is in 2wD) when i let off the gas it would go away but vehicle would lose speed real fast. i had front tires balanced and also found 2 bad tie rod ends, which alleviated a little of the vibration but it is still very prominent. now there is also a vibration at low speeds, before coming to a stop and when taking off from a stop. the rear drive shaft does have some play in neutral at the rear end, and it almost seems like its got the wrong u joint in it, like it is a hair too small, the play is between the ujoint caps and the retaining clips on the yoke (not to be confused w. snap ring). not sure why this would be? i only drove it once before i added lift and tires but i do not remember it vibrating this bad. what my question is from here, is first, would the small amount of drive shaft play be causing this much vibration, and second, would the 3" blocks in the rear throw the drive line angle off enough to vibrate this bad? (someone on here said no if its under 4"s of lift??) i checked trans. and transfer case mounts and they appear to be fine. is there anything else i should be looking for? sorry for long post, i'm new in diagnosing 4x4 components, and trying to save money if at all possible. found a lot of related posts but still looking for insight. thanks in advance!
