Got my new PM starter installed. Only problem is now it has a 2 second delay before the starter disengages. Tried to shim some more but no luck. Did some research and found these newer permanent magnet starters do no like having a jumper between the terminals. Looks like I may need to remove the remote (Ford) solenoid and run the small starter wire back to the new starter. I've always ran these since I would get GM starters that would suffer from heat soak especially on my Typhoon.
Has anyone else ran into this with the newer PM starters and if so what did you do? I assume everyone is running the small starter wire directly to the PM starter like original factory. I suppose I could re-wire the Ford so it's only driving the smaller wire and connect the starter directly to the battery.
The remote solenoid kit:
Jumper:
Wiring diagram of my old starter:
Why does my starter seem to “run on” after the switch is released?
This is a common complaint on permanent magnet starters, although it can occur on any permanent magnet starter in the right conditions. This situation develops when the ignition terminal on the starter is “jumpered” to the battery terminal on the starter and a remote solenoid is used. Permanent magnet starters can actually produce power if they are driven from an outside source (i.e. the starter will act like an alternator once the engine fires and starts spinning). The current produced in the starter for this second or so will flow from the starter’s battery terminal to the starter’s ignition terminal and hold the solenoid in. This will cause the one to two second delay in the solenoid release and an irritating noise. The solution is to wire the starter per the instruction sheet, which will ensure that the ignition switch terminal goes dead the instance the key is released.
If you try to power your GM PM starter with a single cable (like a Ford) you'll experience delayed drive disengagement. The problem stems from a PM starter momentarily acting like a generator after battery power is removed, keeping the solenoid energized through the "jumper wire" for 1 - 2 seconds, after the engine starts. The consequences are really annoying!
The only way to avoid the problem is to wire it like a Chevy!
Here's why:
Ford energizes their solenoid and starter motor at the same time through a shared battery cable that is switched by a remote relay. The Ford solenoid serves the single purpose of engaging the starter drive with the ring gear. Ford uses a single-step process. The magnetic field that moves the solenoid is the same magnetic field that turns the motor. A PM motor cannot generate enough power to run itself.
GM energizes their solenoid through a dedicated circuit that is electrically isolated from the starter motor. On GM, the solenoid doubles as the starter relay. So, the solenoid engages the drive with the ring gear, then closes a high-current switch to energize the starter motor. GM uses a dual-step process. The magnetic field that moves the solenoid is independent from the magnetic field that turns the motor. A PM motor can generate enough power to keep the GM solenoid energized if jumpered directly to the power lead of the solenoid. Confused?
Bottom line, use Powermaster's philosophy: Wire a Ford like a Ford, and a GM like a GM.
Jumper:
