With the key on, what does the gauge read with the sender disconnected now? What does it do with the gauge wire (not the pump power!) Grounded under the same conditions? If the gauge doesn't max out both directions, the problem isnt (entirely) the sender.
You can connect the sender outside the tank and move the float to see if there is a dead spot, but you will probably be able to see on the metal wrapped contact area if there is a dead spot or lot of corrosion. You can try and clean it up if it's corroded.
If you don't need more fuel pressure, and know you won't in the future, then a stock replacement will be fine. Nothing wrong with the upgrade pump, but at this point if I was considering that I'd probably go with someone like Walbro.
Delco pump should come with the in-tank sock filter and hose, not sure about the aftermarket stuff.
