New old tools
the last one is and optical rpm device and
2nd to last one is a metal hardness tester why you need that I don't know yet
I have had two of the Stant radiator testers given to me by retired mechanics..
Was thinking of making an adapter for one of them to allow it to be used to pressurize a fuel tank ,then I could use it to prime the fuel system on my diesel pickup if it ever runs dry on fuel,also would make detecting weeping hoses & leaks easier..
Been wanting a pressure washer for a while now,but I'm torn whether to buy one or just rent one--the gas powered ones work better from what I have seen,but then you have another engine to keep running,and they sit a lot,an electric one might be better in that respect..
Most used ones I've seen in my price range have cracked pumps from not being drained and filled with anti-freeze and left in an unheated garage or shed..some don't seem to last long either,so renting one might be the better option in a way..
The electric on from harbor freight does OK until you by the wand from Amazon
Then it makes it a nice little car washer
If you doing jobs get gas one
