Well it took almost 2 months, having kids takes a lot of your time, but I finally got my 3" ORD lift on. Replacing the wore out factory springs with these new springs and shocks definitely made the ride better and now I do not rub the 33" tires every time I turn. Got the sway disconnects in, but still need to get the steering box brace installed. Taking it to get aligned tomorrow. Also got the softopper and have been enjoying it.
there is definitely a little body work to be done eventually. The body is pretty straight, but there is some rust and the clear coat is peeling on the hood and the cab. A good friend owns and runs the alignment shop so I trust him and wanted him to run through the front end just to double check everything.
