new poly bushings
gangbox1
Registered Member
HIGH DESERT NM
hello all, im replacing my 38 yr old body bushings in my 72 blazer.my new kit has 20 pcs.i see that the old bushings are sandwiched in between the frame mounts and the body. it looks like i have 6 mounts per side ,2 bushings per mount including the radiator. that would be 24pcs on the count of the mounts and i only have 10 pairs(20pcs). do i leave certain ones out? help appreciated thxs mike:eek1:
Sounds like you got shorted on the body mount kit...
The complete kit is supposed to have something like 94 total parts in it (including bolts, nuts, washers, etc)
LMC has a great exploded view diagram of the body mounts and hardware in their catalog and on their website. You can use that as a reference to compare and see what is missing.
:usaflag:
