Run a 195 stat. 180 is a bit on the cool side for an IDI motor IMO. What year motor is it? Different years use different stats, and some have been discontinued by GM. They are still available aftermarket, but some Stant units are Chinese in origin while the CST's are known to be garbage.
I use good ol' low silicate green antifreeze like Zerex and add the proper amount of Cummins/Fleetguard DCA4 or NAPAKool supplemental coolant additive to protect against possible cavitation issues (although I have never heard of any problems with cavitation on the GM diesels, I prefer to be cautious
). I also used Redline Diesel Water Wetter - I can't say if it will help, but I figure here in the Valley of the Sun it can't hurt.
If you want to use an extended life antifreeze I would suggest
Zerex Extended Life Antifreeze. I have seen way too many systems with Dexcool that were rotted out. I know it is supposed to be improved now, but I still have my doubts. Regular green stuff protects aluminum just fine. You just have to change it every couple of years...
