KansasTwister
Lines look good, both the upper and lower fitting are leaking between the line and the fitting, just a barely drip off top, but a slow pulse at the botttom. If the radiators flares were made wrong how would I tell? It never leaked before the new radiator. This is on my 83 by the way, lines are perfect shape. Old radiator is unusable, but only damaged on passenger side.
Ive loosened the lines, made sure they were straight and inserted, and re tightened them and made sure they were tight by the way.
