Hey guys!
I'm in the middle of installing my 4" lift on my truck. Basically a set of custom made 4" lift springs up front with stock shackles, and a set of 63" 2500 HD springs out back.
I haven't got started on the back yet, but I got my front diff bolted back up this afternoon since finishing an overhaul on it (new bearings, seals, brakes, hubs, and steering). Anyways, after I bolted it in, I went to bolt up my brand new Rancho RS5000 shocks, and they don't fit! I triple checked the part number before buying, which is for 80 - 69 4x4 trucks with 2.5 - 4" of lift, and on the shock themselves.
They are significantly too short too, even pulling the ram all the way out doesn't make them long enough to reach the lower mount
My frame and diff should be stock 1979 3/4 ton stuff, and I know that the springs are definitely 4" lift springs cause I measured them. The mounts are just like any other truck I've seen, so I dunno what I messed up...
Any suggestions?
Any suggestions?
