my 78 blazer 350's stock temp gauge runs at about 3/4 towards hot. this is the way it was when i got it a few weeks ago so assumed the temp is ok just an inaccurate gauge and/or sending unit. took it on 2 long drives, each for 2 hours, no overheating. gauge gets up to 3/4 and does not go up or down.
i decided to freshen up the cooling system since i was not sure how old everything was, new hoses, coolant and since i was in there i change the thermostat and coolent temp sensor. afterwards, the gauge now climbs all the way to max. since i changed 2 things i'm trying to pinpoint the problem, which i'm guessing is either a faulty temp sensor but more likely the new t-stat is stuck closed. i made sure to install it in the correct position and not upside down.
i let it idle it with the rad cap off and i believe when the stat opens up the coolant level should drop and the upper rad hose should become pressurized. i did not see that happen.
whats the best way to tell if the t-stat remains closed?
FYI- the parts i installed were a Mr. Gasket 195 degree (#4365)
http://www.summitracing.com/parts/MRG-4365/
Standard Temp Sender (#SMP-TS6) http://www.summitracing.com/parts/SMP-TS6/
