OrngK5
Registered Member
Back again looking for answers from the guru's, I noticed a new ticking noise coming from the engine bay while idling from my 1978 K5 400 w/ T350. It started a bit rough this morning, while cranking over it sounded like a belt was loose once it finally fired up. I wasn't able to hear if the 'ticking' increased while reving the engine or not, but while driving only a few blocks to the gym, the engine seemed to 'hesitate' and the RPMs dropped from 2500 back to 2000.
It did this three times until I finally babied it into the parking lot where the "tick tick tick tick tick tick" noise was very pronounced. I want to say it seems louder on the passenger side, underneath the valve covers. It stayed constant with the engine idling, no unusual smells, no leaks, no discoloration of exhaust from the exhaust pipes. Some answers while searching were exhaust leak, loose lifter, loose rod, or distributor cap hitting. Would any of those cause the engine to hesitate at higher RPMs?
Thanks for any advice you could give, and PS, my last problem was the U-Joints.
